Discussion topic: Need a pac code for Sky mobile to Sky mobile
This message was authored by: Paul+MG
I have recently moved over to Sky mobile. And for some reason they sent 2 sim cards. I activated one, used my pac code to transfer to my old number over from my previous network provider, which it has done today.
However this sim card only had 100 mb on it so it ran out of data straight away after leaving home. How do I now get another pac code to transfer my phone number to the other Sky sim card?
Re: Need a pac code for Sky mobile to Sky mobile
You can't port a number between Sky sims, the simplest option here would be to upgrade your data plan on the sim you have activated.
Avatar for Paul+MG
The problem is, the other sim is the one I have 40 gb on which is meant to be the one I am using
@Paul+MG  Your only other option now is to port the number from the incorrect sim to another Mobile Providers Pay as Yo Go sim, then port that back in to the correct sim.
