Discussion topic: My order was cancelled
This message was authored by: Saeed+Tandel
My recent order was cancelled why I didn't get it
Re: My order was cancelled
@Saeed+Tandel
It’s possible you may have failed one of the credit check(s). For a sim deal it’s just a soft credit check, for a device there’s also an enhanced check. See this link for Skys guidance ~
https://www.sky.com/help/articles/credit-checks-sky-mobile
Be aware that if you keep trying to order the device this could further impact your credit score. If you contact Sky they would be able to confirm that’s the reason your order was cancelled but not why you failed the credit check in the first place as they are not allowed to view your credit record. You would have to sign up to a credit reference agency like Experian or Equifax, which would give you access to your credit record.
Also perhaps check that Sky have the correct spelling of your name.
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer so you’d need to contact Sky to chase it up.
This message was authored by: Jasmin20
This also happened to me yesterday
@Jasmin20
The same advice applies as given to the OP.
