Discussion topic: My Samsung s23 fe is lost sygnał with WiFi
This message was authored by: Stanislaw+Zieziul
I have a problem with my new phone, I have had it for two months and from the beginning it has been losing signal with my home WiFi network and also with the mobile network, but often with my home network, I don't know what is causing it, I have tried all your advice from resetting the phone and settings, nothing helped, I believe that the phone has a technical problem and resetting it will not help
Re: My Samsung s23 fe is lost sygnał with WiFi
If you believe the phone to be faulty then you'll have to return it as follows:
https://www.sky.com/help/articles/sky-mobile-phone-or-tablet-repairs
