Discussion topic: My Number/Phone not updating following move to Sky from O2
This message was authored by: Katem122
Hi, I have moved back to Sky from O2 and had the PAC code to transfer my original number which has all worked OK apart from the Phone/My Number is still showing the one allocated by Sky. I've tried to change multiple times but it never saves. I've also restarted a few times.
I'm getting the message that iMessage & FaceTime is using the nbr but it's not registered to my phone as above and I can only keep using it until it expires.
I'm not sure what else to try. Thanks
Re: My Number/Phone not updating following move to Sky from O2
It might be worth calling Sky on 150 and asking them to send you a replace my sim as that will come with your transfered number so should fix these issues.
