Discussion topic: Monaco roaming charge
This message was authored by: Katedixon
Hello.
I've seen the roaming charge for using 0.12GB of data in Monaco, which is absolutely insane!
I used more data in France with only being charged a few pounds.
I have lots of roll over data in my piggy bank, please can you use this to avoid such a high charge please?
Many thanks,
Kate
Re: Monaco roaming charge
@Katedixon  Monaco is not classed as Europe but Rest of the work, all relevant romaing charges are detailed here https://www.sky.com/help/articles/sky-mobile-roaming-rest-of-the-world
Tariff guide is here https://www.sky.com/help/articles/sky-mobile-tariff-guide
It is advisable to check before you travel.
@Katedixon
For France the charge is £2 for every 24 hours where Monaco is a rest of the world country where these charges apply:
£2,160 per GB (yes this is correct)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
All is explained here:
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Unfortunately not.  Any 'rest of world' location is by billing only.
(Too late now) but Sky has advice for 'Accidental Roaming': https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges  (Monaco is explicitly listed)
You can try calling Sky (on 150) and see if they can do anything under goodwill.  I presume your spendcap wasn't set?
@Katedixon
France is in the EU where £2 'roaming' applies.  Monaco (quite famously) is not, mostly on account of been an actual old-fashioned monarchy.
