3
This discussion topic has been answered Discussion topic: Mobile swap help
This message was authored by: Alfie2345
Mobile swap help
Hi.....I swapped my Samsung S23 for the S26 back in May. I originally asked for the S26 5G then decided to change to the S26 Ultra 5G. I sent both back the S23 and S26 back to Sky in the same package but the S26 5G is still showing on my mobile account and I have been charged for having this. I only have 1 device....the S26 Ultra now so should not be being charged for 2. Can someone help at all please on how to remove the 2nd device off the system and refund the payments made in error. Thanks Mark
This message was authored by: daveNOS Answer
Re: Mobile swap help
@Alfie2345 Did you inform Sky you where sending back the S26 5G?
Avatar for Alfie2345
Yes I spoke to someone on the phone to arrange them sending me the S26 Ultra and sending the S26 5G back.....so they definitely knew it was coming back.
@Alfie2345 You will need to call Sky to see why they haven't acknowledged the return, i suspect though that returning it with the S23 instead of on its own with its own packaging may have caused the issue.
