Discussion topic: Mobile roaming in spain
This message was authored by: Andrea0106
Hi, is it best to do sky roaming at £2 a day? How much data can you use? Thanks
Re: Mobile roaming in spain
The Roaming Passport Plus (£2 for 24 hours) is the only option with a Sky dataplan.
There's a fair usage limit of 25GB per dataplan per billing period.
@Andrea0106
As stated for that destination it should cost you £2 for each 24 hours use of your home allowance ~ but if you are a Diamond VIP member the daily roaming is free in Roaming Passport Plus destinations.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage due to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-moblle-tair-usage-policy
Perhaps be aware that 25GB of data really isn't a lot if you are used to having an 'unlimited' allowance at home: it's only a few hours of high definition video streaming over 5G, for example.
