Discussion topic: Mobile calls not working
Message posted on 18 Sep 2026 02:24 PM
My daughter is having trouble with her phone ,if she tries to phone out, it rings for a couple of seconds and then says "call ended". If someone trys to call her it says "number doesn't exist" (or similar) notice. It appears other Sky Mobile customers have been having the same issue lately.
Message posted on 18 Sep 2026 04:05 PM
Re: Mobile calls not working
Do any network issues show here for you:
https://www.sky.com/help/servicestatus/mobile
Message posted on 19 Sep 2026 03:15 PM
Is the device android or iPhone/iPad with cellular? If iDevice then is it running iOS27? I wonder if the new connectivity assist setting under WiFi is causing problems as it uses cellular connection at the same time as WiFi for a more stable connection. Otherwise turn airplane mode off then on & restart the phone.
I don’t work for Sky.
If I have helped then please leave a like.
