Discussion topic: Mobile Data Setting
This message was authored by: TrishD
Mobile Data Setting
Hi! I've recently changed to Sky Mobile from Vodafone and I'm struggling..! Is mobile data supposed to be set on Personal or Travel?
the last few days, I don't receive any emails or WhatsApp etc until I'm connected to WiFi. When I'm out and about and try do a google search, I can't!
 Thanks for reading!
Re: Mobile Data Setting
@TrishD
Set your Sky sim to personal if you are not abroad and travelling.
Make sure mobile data is turned on when you are not at home and connected to your Wifi network.
Avatar for TrishD
Hi, thanks for your reply.
Now I have mobile data switched to personal and the option to allow mobile data switching off.
Then under Sims I settings I have travel set to off and personal set to on.
Is this correct?
When you are home connected to wifi you can leave this as off. When you are not at home this needs to be set to on.
