Discussion topic: Macbook Pro M4 Pro
This message was authored by: Ash102
Macbook Pro M4 Pro
im looking at the m4 pro macbook, but im not sure what spec id be receiving as it doesnt say all the specs on the listing?
the base model one is 512GB if i go for the 1tb option does it come with the higher core count? it just doesnt say and its alot of money for a maybe.
Avatar for Ash102
Re: Macbook Pro M4 Pro
Can confirm the 1tb version was the 14 core cpu and 20 core Gpu 🙂
This message was authored by: ab101_
how much RAM does it have? and are the specifications not customisable?
Avatar for Ash102
24GB Ram , no the cpu and gpu upgrades are not customisable with sky so was unsure on exactly what spec I'd get but I came with the higher spec anyway
