Discussion topic: Kenya roaming
Message posted on 05 Sep 2026 04:25 PM
Kenya roaming
As soon as I landed in Kenya I got charged £200 for data. I thought it was £2 a day.
im now blocked from using data so I not have the daily charge in Kenya ??
Message posted on 05 Sep 2026 04:30 PM
Re: Kenya roaming
Kenya is a (very expensive) Rest Of The World destination.
Message posted on 05 Sep 2026 04:31 PM
Re: Kenya roaming
Did you check here before you left the UK because Kenya is not a £2 daily roaming country so as you have found out you are charged per GB what you use and this can be as high as £2,160 per GB (yes this is correct):
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Message posted on 05 Sep 2026 05:08 PM - last edited: 05 Sep 2026 05:48 PM
Re: Kenya roaming
Unfortunately apart from some of the north coast countries and South Africa itself, the vast majority of the continent is not covered by the expanded £2 roaming.
I really wish Sky wouldn't refer to 'global' in this context because that's potentially so misleading. Of roughly 195 countries on the planet, £2 roaming covers 120.
