7
This discussion topic has been answered Discussion topic: Keeping same number
This message was authored by: Ansdell1
Keeping same number
Hi
i am existing sky customer, just received my new SIM cards. I want to keep my old number, but there are no clear instructions for existing user only if you you transfer from another provider, can someone please help?
Re: Keeping same number
@Ansdell1
You can't use a Pac code to move a number from one Sky sim to another Sky sim so you have a few options.
You could call Sky to ask them to cancel this new sim you activated and then use the one you have.
You could either use the sim you have or if you want to transfer the number you have to the new sim then you would need to use a Pac code to transfer your current sim number to a PAYG network and then use another pac code you get from them to transfer it back to your new Sky sim.
@Ansdell1
Avatar for Ansdell1
Why can't be a simple process moving from 2gb to 10gb and keep my old number.
It can be if you had ordered the 10GB data plan on the sim you already had but from what you have said it appears you ordered a new sim.
Avatar for Ansdell1
I am currently on 2gb monthly plan, during my broadband renewal sky offered me 10gb plan for less than existing plan . They sent me new SIM card which requires activation, however, I want to keep my number but my understanding from your answer it is not possible. Am I missing something here.? I am no technical person, just need step by step instructions how to use the new upgrade.
@Ansdell1  Yes, you should have upgraded the exisiting sim, however you wouldn't get the always same deal as these deals are always for new/additional sims.
The adviser should have explained this to you.
This message was authored by: TT_Hatter
I'm upgrading my phone and I'm with sky mobile how do I keep the same number because I'm upgrading my phone with them and still gonna be with the network
@TT_Hatter
Just put the sim you have already got into your new phone and if you are sent a new sim then do not activate it then it will be cancelled.
