Discussion topic: Issues at Sky
This message was authored by: DDTPK
Issues at Sky
Tried to change my sim plan (three times) system keeps crashing and nobody available on the phone!
Re: Issues at Sky
@DDTPK
Agents are available, there's just probably a high volume of calls especially after a period of bad weather / storms.
Re: Issues at Sky
@DDTPK
Just stay on the line for as long as you can as you should get to someone after a while. You can also contact Sky via one of the social media links at the bottom of the page.
Avatar for DDTPK
Re: Issues at Sky
Tried chat bot, no use. Spoke to the wrong department, got transferred, call got dropped after 10-15 mins, called back 3 times since this morning, every time it specifies they are having technical difficulties and to call back later, then call gets cut off.
