Discussion topic: Issue with number transfer
This message was authored by: AmyJohnstone
Hi, I've just bought a new phone and moved to sky from Tesco, I've kept my number and had the message to say my number has transferred across, but I can't send texts or revive calls, I can only use WhatsApp and iMessage which is data based and in my settings it's the wrong number and won't let me change it, can anyone help?
Re: Issue with number transfer
@AmyJohnstone
If this is an iphone refresh the network settings so go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
