This discussion topic has been answered Discussion topic: Iphone Air E-sim ?
Message posted on 23 Sep 2025 01:43 PM
Good Afternoon
I have ordered a swap for my Iphone 16 and i am
swapping for an the new Iphone Air
The question i have is regarding the E-sim
I have a physical sim with contract , which i
intended to just put in my new iphone air
However, i've just realised that the iphone only uses an E-sim
What do i need to do now, plz
Should i have ordered the E-sim with the phone
I dont know if i need anything to enable E-sim
Such as a bar code or activation code
please advise if you can
Thank you in advance
Message posted on 23 Sep 2025 01:47 PM
@Anonymous
If your current iPhone takes esims then you should be able to convert the sim you have to a eSIM:
https://www.sky.com/help/articles/esim-sky-mobile-convert-sim
Then move it to your new phone:
https://www.sky.com/help/articles/esim-sky-mobile-transfer-sim
Re: Iphone Air E-sim ?
You can convert your physical SIM to eSIM: https://www.sky.com/help/articles/esim-sky-mobile-convert-sim
@Anonymous
Message posted on 23 Sep 2025 02:17 PM
Hi
So i don't have to place an order the e-sim from sky
and i dont actually buy an e-sim , i just convert my physical sim to e-sim myself
can i do that on the day i receive my new iphone air
I was confused when i realised the phone only uses an e-sim and i have a physical sim with data plan
I really do need to keep my number
Thank you for your reply
Message posted on 23 Sep 2025 02:31 PM
@Anonymous wrote:So i don't have to place an order the e-sim from sky
Yes.
If you order a new eSIM then it will be a new number...
Message posted on 23 Sep 2025 02:33 PM
This is confusing me too. I am switching from iphone 15 to iphone air. My new phone is arriving today. I just hope its an easy process. Do we convert old iphone to esim first and then move it to new phone or the physical sim is moved to esim without forst converting it to esim. There is an article on quick transfer from apple devices but sill a bit confused by it. And as you say it sayd about purchasing an esim.
Message posted on 23 Sep 2025 02:59 PM
Hi,
I am the same, titally confused
I just received an email from sky saying the
iphone air onky uses esim and i will need to order one
However i can't order one unless i add a data plan which i don't need
Then if i do order one, i will get a different phone number ( which i do not want )
I must keep my old number
Please please let me know how you get on sorting your phone out
If you don't mind
Did you order an esim when you ordered the phone ?
I have never used esim before
Thanks for your reply
Hopefully we will both get our phones sorted 😁
Message posted on 23 Sep 2025 03:11 PM - last edited: 23 Sep 2025 03:13 PM
It's arriving any minute but will activate later on. I will start by switching on iPhone air and hope it guides me ok! Or may call sky if still confused. But I will report back later.
No I did not order an e sim but the e mail seems to say that's what you need to do.
Message posted on 23 Sep 2025 07:32 PM - last edited: 23 Sep 2025 08:13 PM
This is a nightmare. I switched on iphone air and it guided me through transferring everything from the old iphone. Then it said choose your number from old iphone to transfer to esim on iphone air. But it didnt work. Phoned a sky advisor and he got me to scan a barcode on old phone and then new phone said activating line and then after half an hour failed.
So phoned Sky again and this advisor said he will e mail a code for a new e sim but I must call Sky again to activate it and not to try and do it myself. So at the moment still using my iphoe 15 and getting nowhere!
now phoned fourth advisor and been told technical team will call tomorrow lunchtime.
Message posted on 23 Sep 2025 10:47 PM
Hi ,
Oh no what a carry , i hope you get it sorted tomorrow.
I guess i will have the same trouble , you would think they would know exactly what needs doing and guide you correctly
Good luck with everything tomorrow and i hope you get a resolution
On another note, what does the Iphone Air look like
I havnt even seen one, but i'm hoping i like it
Really interested in getting a lighter easier to carry about phone 😀
I had a 15 plus nice subtle pink one,but it was too big and heavy
Then i went for the 16 but i hate the pink colour its too vivid for me
i'm hoping i will like the Air (pale blue)
Fingers crossed
Good Luck and thank you for replying
Everything is crossed for you .. ,.. and me, when i get mine 😀
Message posted on 24 Sep 2025 07:58 AM
Thanks. To start with it seemed ok. The quick transfer instuctions on the news section on here said its quick and easy! The phone does look quite nice. Very slim and larger screen to the iphone 15. I havent had a phone before with Apple Intellegence so have to get my head round that.
I am not the only one having issues. Look at another thread on here Esim issues Absolute shambles. Goos luck when you get yours. Hopefully this tech guy whoe is calling later will sort it out.
Message posted on 24 Sep 2025 07:14 PM
If only it were that simple! I have just been told NOT to convert the physical sim to esim on my currrent phone but to wait 24 hours and it shouls be fine.
Message posted on 24 Sep 2025 07:41 PM
Hi
I did the transfer from my iphone 16 to Iphone air today after my phone was delivered, i thought it wasn't due for another few days
I didnt add any mobile network sim yet
Just trying to sort my phone out, so i will leave the rest till tomorrow
Fingers crossed for you tomorrow
Message posted on 26 Sep 2025 08:18 AM
Hi
i hope you don't mind me asking, but did you get the esim sorted
What do you think of the phone
I received my phone but had trouble with esim
installation, but the back of the phone gets very warm vey quickly
Not sure if all this carry on with the esim is worth it,i havn't solved it yet
I have asked for a replacement sim because my normal sim was turned off and i lost the use of my "swap phone"
I am seriously thinking of returning the phone and keeping my "swap"
I've only had the phone 2days and my head is spinning and i can't even use it
Message posted on 26 Sep 2025 10:35 AM
@Anonymous No still not sorted. Yesterday spoke to a fifth advisor who said there is a problem and sky are aware of it and trying to sort it and expect it to be resolved by tomorrow. He did give me a credit to cover the cost of the old phone as I cannot send it back until I get this eSIM working.
luckily I still have use of my phone but also have iPhone air on wifi so can use it for anything but phone calls.
I quite like it as it has additional features that my old one did not like Apple Intelligence.
still unsure about the eSIM installing properly. I have been sent four replacement esims. I have to be sure it will transfer before I do this as don't want to lose service.
I am thinking that erasing the new phone and starting again.
