Discussion topic: Incoming and outgoing calls “ending”
This message was authored by: Melijade
Calls incoming and outgoing are ending as soon as it's dialed or comes through to the phone. I can see someone is calling but as soon as it appears it says call ended.
same with dialling as it states call ended as soon as it's dialled
Re: Incoming and outgoing calls “ending”
Are you able to call Sky about this, if not as you will need to contact them about this issue then you could contact them via social media for help as they might want to send you a replacement sim to try.
Avatar for Melijade
I can't call any number on my phone unfortunately and dont have another phone to use 😞
