Discussion topic: Imoo Z1 network cover Sky Mobile Ireland
Message posted on 25 Feb 2025 08:25 AM
Hi I have a kids smartwatch the imoo z1 and I'm finding the coverage dreadful since switching from 48 to sky mobile Ireland keep losing signal and not reconnecting
I have been chatting to mfg (China) but not getting very far one thing I found was there was no apn settings detected on the parents app. I have added this manually today to see if that helps but sky weren't very helpful on the subject matter.
just as an fyi
APN mobile.sky
username none
password none
MCC 234
MNC 57
only just done so will monitor during the day
Message posted on 25 Feb 2025 08:34 PM
Re: Imoo Z1 network cover Sky Mobile Ireland
manually input the following apn settings in the imoo app
APN: mobile.sky
username:
password:
MCC: 234
MNC: 57
This seems to have resolved it
Message posted on 26 Feb 2025 09:31 PM
Thank you ... I don't have MNC or MCC fields to set in network settings though
Message posted on 26 Feb 2025 09:49 PM
Hi @Niamhie101 was the watch working ok without the MCC/MNC being set?
if not update the app with the ones I've supplied, connect to wifi and leave it connected for about an hour (or more) as it syncs very slowly with the watch
Message posted on 26 Feb 2025 09:55 PM
Sorry misread your comment
make sure you are connected to wifi first
in the app > watch settings > access point name (apn) it may say no apn and a button to add apn press this fill in as per my information and save it
leave the watch connected to WiFi for about an hour (or more) while it syncs turn off the wifi and check the chat etc works off the mobile network
Message posted on 26 Feb 2025 10:00 PM
Not a watch, an iPhone
worked fine on Vodafone
Message posted on 26 Feb 2025 11:10 PM
for iPhone it's just mobile.sky in the apn that's all that is required In the mobile data network settings
i
