Discussion topic: How to send phone for swap
Message posted on 04 Dec 2025 01:30 AM
I recently ordered a new phone, and need to send the old one back as a swap.
i have the packaging and returns label, which I believe I am supposed to use to send the swapped phone back to them - but as the phone value is over £100 it suggested to send it back as special delivery, not using the prepaid label included in the phone. If I do it this way, how would Sky know the phone was from me? The special delivery label wouldn't have all the details they include on the pre paid label- the customer reference, or either of the barcodes/qr code if they are using them for internal purposes to track the return.
Message posted on 04 Dec 2025 07:13 AM
Re: How to send phone for swap
Hi @Robtimus89 why can't you put both labels on ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 04 Dec 2025 08:58 AM
If there are 2 labels, which one does Royal Mail scan? It would depend on whatever way they picked the parcel up or put it through one of their machines - so they could scan the tracking on either side of the box, and the tracking would update at different points against the different numbers.
Message posted on 01 Jun 2026 08:43 PM
Hi, I'm having this problem did you figure this out?
