Discussion topic: How do I order a replacement eSIM
This message was authored by: Nataliaesque
So I ordered an eSIM for the first time, no idea on how to set it up, put in the wrong code three times and it said to reorder a new eSIM but I can't find out where to do it on the My sky app
Re: How do I order a replacement eSIM
Hi @Nataliaesque  if the last one didn't activate and if you need to order another esim just go here.
https://www.sky.com/shop/mobile/plans/
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Nataliaesque
But does that mean I need to buy another esim?
@Nataliaesque
It does but as you failed to activate the one you have it will be cancelled so you should not be charged for it.
