Discussion topic: Help with simcard
This message was authored by: Dylan45
Help with simcard
I'm with sky and got a sim card sent out with my phone how do i active it with keeping my old number
Re: Help with simcard
You can't.  (You cannot port numbers within a network)
You move your current SIM across.
@Dylan45
This link explains how to activate it:
https://www.sky.com/productsettings/mobile/activate-sim
You can only use a pac code to transfer your current number to it if it is on a different network and isn't on another Sky sim, if it is you would need to get a pac code to move it to a PAYG network then get another pac from that network to move it back to this new Sky sim.
