Discussion topic: Help with product
Message posted on 24 Apr 2026 08:16 PM
Help with product
I tried to take an Apple Watch out it was accepted then got cancelled
Message posted on 24 Apr 2026 08:20 PM
Re: Help with product
@Amber100 wrote:I tried to take an Apple Watch out it was accepted then got cancelled
Sounds like the credit check failed. You'll have to call Sky to see, us other customers here cannot help.
Message posted on 24 Apr 2026 08:27 PM
This might have happened if you have failed the second more enhanced credit check that takes place. You can call Sky to find out if this is what has happened as they can answer this for you but as Sky is not allowed to view your financial records they can not tell you why you have failed the check. You might want to look into this yourself by signing up to a site that allows you to view your records, one credit checking site they use is Experian so you could sign up to a free trial with them, just remember to cancel.
If this is the case then any upfront charges that you have paid should be refunded within about 14 days.
As Sky are not allowed to access your credit records all they can say is the reason for the cancellation so if you have failed the credit check then this will be something you need to look into yourself. You could sign up on a free months trial at somewhere like Experian which will give you access to your credit record. If you do this remember to cancel before the free month finishes.
