Discussion topic: Help with esim
Message posted on 23 Sep 2026 10:06 PM
Help with esim
Message posted on 23 Sep 2026 10:15 PM
Re: Help with esim
You have a few options:
Activate the sims that are one the way to you and then convert them to an esim:
https://www.sky.com/help/articles/esim-sky-mobile-convert-sim
Don't activate the sims that should be with you soon then they will be cancelled and instead order an esim or esims via here:
https://www.sky.com/shop/mobile/plans
Message posted on 23 Sep 2026 10:20 PM
Re: Help with esim
Thank you for the reply.
So can I activate as an eSim before I receive the physical SIM?
Message posted on 23 Sep 2026 10:24 PM
Re: Help with esim
If you plan to order an esim and not activate these sims that are on the way then yes you can do this.
Message posted on 23 Sep 2026 10:32 PM
Re: Help with esim
That's great advice! Thank you!
Message posted on 23 Sep 2026 10:33 PM
Re: Help with esim
And them can I use a PAC code to bring across my old EE number?
Message posted on 24 Sep 2026 05:36 AM
Re: Help with esim
Once the esims are active then yes you can transfer you number via a pac code.
