Discussion topic: Help with data/sim?
This message was authored by CJM This message was authored by: CJM
Help with data/sim?
I’ve just signed up to sky and kept my old number. I have two data plans - the first for 100mb free which is registered to my number and the 2nd data plan (for 25GB) shows under another number? Have I set it up wrong? Also, when I’m outside away from my wifi, my internet doesn’t work and I can’t use my banking apps or anything like that. Can someone help me please? xx
Re: Help with data/sim?
If you have two sims then they will each have a different number as it isn't possible to have them both on the same number.
Have you turned on mobile data when you are not at home ?
This message was authored by 63johnw This message was authored by: 63johnw
Hi @CJM  if you are using the 100m sim in your phone then there is a very good chance you have used all of your data and that is probably why you can't use mobile data when away from your home. 100m is a minute amount of data and will last only a matter of seconds/minutes with todays smart phones.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
CJM
Thanks for your help, yes, my mobile data is on when I'm away from home.
