Discussion topic: Greece not Albania
This message was authored by: moreton4
Greece not Albania
Hi,
I have just returned from holiday in Corfu and have been charged £140 for Albania roaming even though I only travelled in Greece.
Re: Greece not Albania
@moreton4
This does happen if you were near the border as per this:
https://www.sky.com/help/articles/sky-mobile-roaming-problems-accidental-roaming
As you need to make sure your device connects to the correct network for the country you are in.
@moreton4
 In the vicinity of any border, it's quite possible to be physically closer to a cell mast located in a country other than the one you are actually standing in: that generally wouldn't matter much elsewhere in Europe but becomes crucial to be aware of at its periphery because of the potentially huge difference in cost (£2 per day vs several pounds per megabyte)
Avatar for moreton4
I wouldn't have minded too much but it was momentarily and cost £140 for 65 meg. Some apps must have been working in the background when it happened.
thats quite a big jump for something I wasn't aware of.
Unfortunately, yes, at the £2.16 per megabyte 'rest of the world' rate, because Albania isn't within the EU/EEA where £2 per day to access a UK bundle applies.
Hi @moreton4  did you remove the data roaming spend cap as that would have at least capped it at £45 ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for moreton4
Good point, I didn't and it did stop working in Greece for the remainder of my holiday due to the spending cap so the cost should be 45 pound. I'll give them a ring as it's pretty excessive otherwise.
