Discussion topic: Going on holiday
Message posted on 30 Mar 2026 09:23 PM
Going on holiday
Message posted on 30 Mar 2026 09:28 PM
Re: Going on holiday
What are you are charged depends on where you are going so where will you be ?
Message posted on 30 Mar 2026 09:29 PM
Lanzarote
Message posted on 30 Mar 2026 09:38 PM
The cost is £2 per 24 hours use and this lets you use your phone as if you were in the UK so calls to UK mobiles and UK landlines are included but calls to local numbers are charged at international rates. Data usage is limited to 25GB:
https://www.sky.com/help/articles/sky-mobile-roaming-passport-plus
Message posted on 30 Mar 2026 09:39 PM
Do I need to change my spend cap? If so can you advise me on how to do this please& thank you
Message posted on 30 Mar 2026 09:43 PM
You might need to depending on what it has been setup as it does say this on the link I posted above:
The £2 pass counts towards your monthly spend cap. If your data usage is set too low or set to £0, it will block you from using your phone abroad. To use the Roaming Passport Plus pass for a week’s holiday, your data usage would need to be at least £14 a month, £2 x 7 days. Check your data usage anytime at sky.com/spendcap.
Try this link or via the MySky app:
https://www.sky.com/myaccount/mobile/sim/x/settings/spend-cap
