Discussion topic: Does data roaming work in morroco
This message was authored by: Aimee62
Just wondering ,
im off to Morroco for a week and I can't find anywhere how much it would be to use my data in Morroco
Re: Does data roaming work in morroco
@Aimee62
You can always check this here:
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
As you will see Morroco is a "Rest of the World" country so the charges will be this:
£2,160 per GB (yes this is correct)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
Avatar for Aimee62
Level 0 icon
£2,000 are you joking that's a lot.
what if I have unlimited.
You might have an unlimited data sim but to use it in Morroco you do have to pay these charges so use 1GB and you are hit with that charge.
Rest of World roaming is not part of your data allowance.
Then the bill would be unlimited too ; )
(Actually, overseas data use is capped at 25GB, so around £54,000 is theoretically possible)
You might remember the story about the offspring of the Scottish politician who ran up an £11,000 mobile bill in Morocco by streaming a football match.
@TimmyBGood wrote:
You might remember the story about the offspring of the Scottish politician who ran up an £11,000 bill in Morocco by watching a football match.
