Discussion topic: Data roaming
This message was authored by: Suzchizz
Data roaming
Why am I getting charged for data roaming when data is off in Greece, used for 5 mins while transferring money yet charging me 2.00 a day, I don't think so ,will sort this when I get back x
Re: Data roaming
@Suzchizz
If you are new to the forum or this is your first post then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Your own post confirms you did use data.
Re: Data roaming
Hi @Suzchizz  as soon as you use a small amount of data, send one text or make one call then that triggers the £2 daily charge. As you said you used data for 5 minutes then the charge is correct.
All Opinions Are My Own
