Discussion topic: Data roaming
This message was authored by: Shell234567
Data roaming
My data roaming won't work as my spend cap is on. I have changed my spend cap for my number but it is saying for my other SIM card/original number the spend cap is on. What do I do
Re: Data roaming
In the MySky app, go to Mobile.
Select the SIM in question and then hit Manage SIM and Manage Settings.
You can change the spendcap settings for that SIM.  Rinse and repeat for any other SIMs.
As an aside, what country are you in?
