Discussion topic: Data required
Message posted on 12 Aug 2026 09:31 PM
Data required
I need to add to my data plan
Message posted on 12 Aug 2026 09:43 PM - last edited: 12 Aug 2026 09:45 PM
Re: Data required
@Darrenn1967 wrote:I need to add to my data plan
Go ahead. You can log onto your account to do this.
Either increase your data plan or purchase 1GB one off.
You may be able to transfer from your piggyback if you have residual data.
Message posted on 13 Aug 2026 04:36 AM
Re: Data required
As suggested by @PandJ2020 … see this link
https://www.sky.com/help/articles/change-your-mix
Increasing the data plan happens almost immediately.
Decreasing the data plan happens at the start of your next billing period.
