Discussion topic: Data Roaming not working!
This message was authored by: mollmoo
Hello, I've recently arrived in Germany, and I followed all steps and turned spend cap off, turned data roaming on, restarted my phone I've checked all my settings and followed the help guides online. My phone shows I have signal and will show 5G/4G but it doesn't work at all. I can't make calls, texts or use my data at all.
Its absolutely essential I get this working and it seems like I'm being sent round in circles with the help guides!
Re: Data Roaming not working!
@mollmoo
Try the troubleshooting in this link
https://www.sky.com/help/articles/sky-mobile-roaming-problems
Additionally could you have exceeded the fair usage policy? https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Roaming using Roaming Passport Plus is now limited to 25GB per billing period.
From Skys own website...
When you roam using our Roaming Passport Plus, we consider that up to 25GB per billing period is a reasonable amount of data to use. If you exceed this amount, we'll assume that you're no longer using data in the way expected of a reasonable customer for periodic travel.
We may suspend your service, restrict your usage, or charge you for the data that you use in excess of these amounts (currently £2.50 per GB), and we'll let you know by SMS or email before we do so.
Also bear in mind if your data usage is set too low or set to zero it will block you from using your phone abroad. You need to have at least £2 for every day you are there (recently offered free for Sky Diamond VIP customers).
