Discussion topic: Data Roaming not working in Montenegro
This message was authored by: TAS13
Hi, I am currently in Montenegro and my data roaming is not working.
I got a welcome message from Sky his morning when I arrived and and have tried everything to reset/check setting etc but it hasn't worked.
Tried to ask sky to resend network settings via text whilst connected to wifi but never received the text message.
I have the roaming passport plus set up so it should work.
I can"t use SMS or MMS or any maps etc
can anyone help?
thank you.
Re: Data Roaming not working in Montenegro
@TAS13
Montenegro is a Rest Of The World destination and not covered by normal passport plus data roaming.
It will be very very expensive to use your Sky mobile there
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Hi @TAS13  Montenegro isn't covered by the £2 roaming charge, it's a very expensive rest of world destination, see page 11, you have probably reached your spending cap.
https://static.skyassets.com/contentstack/assets/blt7f2b03fd02c7fe60/bltb1ca3ee021ffd768/68c1f143e2f...
All Opinions Are My Own
This message was authored by: Shell63
Get a local SIM card . Do not try to use any data in Montenegro the costs are extortionate.
