Discussion topic: Checking direct debit payments
This message was authored by: As34
Message posted on 09 Apr 2025 01:44 PM
Hi, I have a direct debit which goes out every month however I had added on insurance. I would like to check which bank account thag is set under
Find out more
Message posted on 09 Apr 2025 01:48 PM
Re: Checking direct debit payments
@As34 No one on he community can check your acount, howe er if you signed up through Sky protect you should have received confirmation of which DD details you used.
Find out more
Message posted on 09 Apr 2025 01:53 PM
If you did sign up to Sky Protect then try using the Sky Protect app.
