Discussion topic: Check if pac code
This message was authored by: Frin
Check if pac code
I can't cancel number on sky sim how can I check if  I still need pac code to Chang number to a new supplier
Re: Check if pac code
@Frin  if you are porting to or from another provider and wish to keep the current number you need to port it  Keep your number | Sky Help | Sky.com | Sky Help | Sky.com
