Discussion topic: Changing mobile phone
This message was authored by Siva+lakshmi This message was authored by: Siva+lakshmi
Hello,
I recently took iphone 13 pro , I would like to change my iphone 13 pro to 13 pro max.
can you help me with this please?
Re: Changing mobile phone
As we are customers here like you then you will need to call Sky. You will only be able to do this if you are still within the cooling off period, if you are then Sky will cancel the device you have and the payments required on it so it would need to be returned and then a new order can be placed, this will mean you are credit checked again.
This message was authored by 63johnw This message was authored by: 63johnw
Hi @Siva+lakshmi  as advised by @caesarome  you will need to contact sky. Call them on 150 to start this.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
