Discussion topic: Changing data plan
This message was authored by: JWestLondon
Changing data plan
Hi all,
needing a bit of a steer please.
I tried to change my data plan to a more favourable one.
Sky now says they are sending me a new sim.
I don't need a new sim and certainly don't want to change my number.
have I done something wrong? I thought my current sim would be automatically updated.
thanks.
Re: Changing data plan
@JWestLondon
See this link
https://www.sky.com/help/articles/change-your-mix
Increasing the data plan happens almost immediately.
Decreasing the data plan happens at the start of your next billing period.
Avatar for JWestLondon
Level 3 icon
Thanks for the prompt reply.
that's what I innocently thought would happen!
but it hasn't.  My data plan remains unchanged. The only option I've got in MySky is 'activate my sim' which is asking for a PAC code to activate my new sim and keep my number. And the emails insist they are sending me a new SIM card.
that's not going to happen. What now?
I haven't got a link for a cancellation that I can see . If I do not activate the new sim they are sending me will it drop off the system?
Thanks . JS
@JWestLondon
If you don't activate the sim they are sending you then it will be cancelled so you will not be charged for it.
