Discussion topic: Changing data plan issue
This message was authored by: Leyton1
I'm not able to swap data plans from 10gb to the unlimited one it just says there's a problem when changing it just goes to error screen
Re: Changing data plan issue
@Leyton1
If that continues give Customer Services a call and the agent should be able to change the data plan for you.
@Leyton1
150 is the free numkber to call Sky on about this.
Hi @Leyton1  are you new to sky mobile ? You need to pay two months before you can change your mix I believe.
All Opinions Are My Own
