21 Mar 2023 09:10 PM
Hi all, I was just looking through my data plan as my allowance had ran out, I noticed my data plan which was 2gb and another plan (3gb) was the same price so I changed my plan to this, my bill has now changed and they have added an extra £10 every month on top for the new plan, it is listed as unlimited minutes, calls and texts. I already had this on my other plan. Has anyone else had this happen and no how to resolve it. thanks for reading, I look forward to your responses.
21 Mar 2023 09:16 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @DBate58 give sky a call on 150 as that sounds like the free calls and texts has been added at £10 when it should be free.
Posted by a Superuser, not a Sky employee. Find out more@DBate58 If it's added another amount to you bill did you definately change the existing plan or order a new one instead? How many sims do you now see on your account?
21 Mar 2023 09:25 PM
Hi I have just changed plan I only have the 2 sims that I have always had, very strange for them to add £10 guess I will have to call them tomorrow.
21 Mar 2023 09:26 PM
Yes I think this is what they have done, very annoyed, guess I will have to call them tomorrow
21 Mar 2023 10:36 PM - last edited: 21 Mar 2023 10:37 PM
Posted by a Superuser, not a Sky employee. Find out moreThere was a similar post the other day - it looks like the legacy charge of £10 is triggered under certain changes. (There used to be a £10 charge per month for unlimited calls but was discounted by £10 if you had TV - this requirement was removed)
22 Mar 2023 04:02 PM
This is strange I have 2 accounts and changed both plans from 2gb to 3gb but only the 1account has added an extra £10. Thanks for your reply I will phone them and see what's going on.
01 May 2023 06:58 PM
I would like to do the same as you, trouble is I don't know if I would keep all of my piggy banked data after seitching. Were you able to keep all of yours?
01 May 2023 07:32 PM
@richard0292 wrote:I would like to do the same as you, trouble is I don't know if I would keep all of my piggy banked data after seitching. Were you able to keep all of yours?
Hi @richard0292 yes you keep all of your piggybank as long as the account is open (subject to the 3 year rule).
01 May 2023 07:38 PM
Thank you for your response.
What exactly does the 3 year rule imply for carrying over unused data?
01 May 2023 08:17 PM
@richard0292 wrote:Thank you for your response.
Unused banked data will stay in your piggybank for 3 years and if not used will disappear from the piggybank. So for example if you banked some data in May 2020 it will disappear this month if you haven't already used it.
