Discussion topic: Can I keep the same data plan when upgrading device
This message was authored by: Letitiacl
I want to upgrade my device, but I want to keep the current data plan I'm on, is this possible?
Re: Can I keep the same data plan when upgrading device
Yes.  If you can't find the option to order without a new data plan then simply move your existing SIM across and do not activate any new SIM.
