Discussion topic: Battery
Message posted on 13 Jan 2026 12:21 PM
Battery
I bought a new iphone16 in September and the battery is not lasting. I have to charge it twice a day and if it gets to 10% at any time is can just power off. My phone had a two year warranty. Can I get a replacement?
Message posted on 13 Jan 2026 12:26 PM
Re: Battery
@JDon101 wrote:My phone had a two year warranty.
Standard warranty is 1 year. Did you purchase additional cover?
Message posted on 13 Jan 2026 12:43 PM
Re: Battery
Hi @JDon101 the phone will need investigation by Apple or sky to see if it's faulty. High useage will drain the battery fast. Once it's been checked then sky will decide if it's to be repaired or replaced if faulty. Personally I would take it to an Apple Store first for them to check.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 13 Jan 2026 02:43 PM
Re: Battery
As an aside, have you checked the phone's battery usage counters? They will show you exactly which app is using the battery.
It may not be a 'fault' but you have a 'rogue' application consuming the battery.
Message posted on 13 Jan 2026 08:56 PM
Re: Battery
I have an iphone 16 pro max & the battery life is awful since ios 26.2. i also read other reports. theres talk that ios 26.2.1 will be released soon so hopefully that will inprove things
