Discussion topic: Albanian data roaming charges when in Greece!
Message posted on 28 Aug 2025 02:07 PM
I have had an additional £200 added to my bill for data roaming charges when I was in Corfu, the charges are because my phone connected to Albania one day.
Up until now, Sky are refusing to reimburse me as they say I should have had my spending cap on. Surely I shouldn't have to pay these charges?
Message posted on 28 Aug 2025 02:39 PM
							Re: Albanian data roaming charges when in Greece!
You incurred the charges, Sky are under no obligation to refund you. If you didn't have a spend cap on then I'm afraid your liable for all & any charges if you connect to a country not in the roaming plan.
The spend cap is there to prevent such charges.
Message posted on 28 Aug 2025 02:42 PM
So it seems. I really had no idea that I needed to see a spending cap. Really would have appreciated some kind of warning from sky, even a text message when I arrived in corfu to warn me of this.
Message posted on 28 Aug 2025 02:55 PM - last edited: 28 Aug 2025 02:56 PM
@Matth1975 The onus is on you to check this info before travelling, all such info is freely available oin Sky's website Using Sky Mobile abroad (roaming) | Sky Help | Sky.com | Sky Help | Sky.com
There is also detailed info about corfu here Roaming Passport Plus | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 28 Aug 2025 03:03 PM
I can't see the detailed info about Corfu?
I did check with sky prior to travelling and they said Roaming Passport Plus would cover me for £2 per day. This can't be uncommon when in north Corfu surely.
Well, I'll wait for Sky's response but I will defo be more careful in future.
Message posted on 28 Aug 2025 03:06 PM
Just spotted the bit about Corfu! Wish I had before.
Message posted on 28 Aug 2025 03:26 PM - last edited: 28 Aug 2025 03:30 PM
It's a common mistake to pick up an Albanian mast. I'm afraid Sky aren't likely to reimburse you. See this link, in particular accidental roaming' near the bottom...
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
(At present the mention of Turkey in that section appears to be incorrect).
