Discussion topic: issue (001) connecting to sky go
This message was authored by: funfur
i've tried getting onto the skygo app but it has the erroe 001 wiith a porblem correcting. I have tried deleteing the app and reinstlling it aswell as deleting the specific folders from files. However it still dosen't work, what else can i do? (im on a mac)
Re: issue (001) connecting to sky go
Are you using a VPN if so it will need disabling.
If not you could try this:
1. Delete Sky Go app from applications folder AND trash.
2. Open Finder then Go from top menu bar
3. Copy and paste one of these libraries and carefully seach for any Sky Go files or folders and delete them (then delete trash) :
~/Library/Preferences/
~/Library/Application Support
~/Library/Caches/
~/Library/Logs/
~/Library/LaunchAgents
~/Library/Cookies
~/Library/Group Containers
4. Then repeat with the next library and so on until all are searched.
5. Delete Trash.
6. Reinstall Sky Go for Mac from sky.com
7. Launch app
8. Sign in
