Discussion topic: Will sky go work without multi screen ? The
This message was authored by SMT2003 This message was authored by: SMT2003
Re: Will sky go work without multi screen ? The
You do not need multiscreen to use Sky Go but what it allows is you to connect the app to a Sky Q box allowing you to view your recordings back via the app and you can also view live channels including those from the BBC via it.
SMT2003
So without multi screen can I watch programs in my sky package live  on a laptop still ?
That is correct.
SMT2003
Thanks very much
This message was authored by Sparkzsta This message was authored by: Sparkzsta
This isn't strictly true as I've tried watching Sky Go through an Apple TV, but get a message to say that I need a multiroom subscription to do so...
I appreciate that I'd effectively be bypassing a multiroom subscription by doing this, but nowhere on the Sky website nor within the product descriptions for Sky Go does it say that you need to have multiroom to use it on an Apple TV.
The posts above do not relate to Apple TV so the answer is correct.
To use Sky Go on Apple TV you do need multiscreen so as I presume you don't have it what happens when you try to use the app ?
Sorry but it does:
https://www.sky.com/help/articles/sky-go-what-do-you-need-help-with
For Sky Go on Apple TV, you'll also need a Sky Multiscreen or Whole Home subscription
This message was authored by Kernow99 This message was authored by: Kernow99
OK.............
On average, new discussions are replied to by our users within 3.6 hours
