Discussion topic: Using Sky Go with Sky Puck
Message posted on 03 Jul 2024 07:56 PM
My Dad recently changed from Sky Q to Sky Stream but it struggling to get the Sky Go app to work on his IPad. Any suggestions would be excellent. TIA
Message posted on 03 Jul 2024 08:30 PM
Re: Using Sky Go with Sky Puck
What is happeing when he tries to use Sky Go on his iPad ?
Message posted on 03 Jul 2024 08:58 PM
Thanks for responding @caesarome , he gets a message saying he needs to upgrade. I can see in his settings that the app is still trying to connect to the sky q box, but we couldn't see an option to change it to the puck.
Message posted on 03 Jul 2024 10:21 PM
There should be a setting in the Sky Go app itself that should allow the connection to the Sky Q box to be turned off.
Message posted on 03 Jul 2024 10:36 PM
Ah right, so you think if we just turn that setting off, it will just connect to the puck instead? I'll pop round tomorrow and try that for him. Thanks.
Message posted on 03 Jul 2024 10:50 PM
Unlike with Sky Q the Sky Go app does not and can not connect to the puck I'm afraid as it has to be used independently of it.
Message posted on 04 Jul 2024 12:33 AM
@caesarome Does this mean he can't use Sky Go with Sky Stream?
Message posted on 04 Jul 2024 09:43 AM
He can use Sky Go @TushDJ but not connect them in the same way you could with Sky Q.
Message posted on 04 Jul 2024 11:13 AM - last edited: 04 Jul 2024 11:14 AM
Sky Go 'works with' Sky Q by using satellite reception for live content (via the dish and the tuning circuits in the Q box) and through accessing recorded content on the Q hardware drive. Neither of those applies when Sky Glass/Stream is at the subscription address, and Go becomes an independent streaming app (as it did when used away from the property previously)
Message posted on 05 Jul 2024 05:34 AM
@caesarome Ok, so he has unlinked the Q box via the settings but still no joy. He's also deleted and redownloaded the app, but he's still getting the same upgrade message 🤔
Message posted on 05 Jul 2024 05:41 AM
A few questions:
Was Sky Q working before he changed to Sky Stream ?
Was he given a new accoint number when he changed ?
Can he access his bills here:
https://www.sky.com/bill/tv-broadband-talk
