4
This discussion topic has been answered Discussion topic: Use of Sky Go clarification
This message was authored by: Paulll+watkins
When I'm in Spain can I use Sky go to record programmes on my tv that's in the UK, or can't it record from outside the UK at all.
Paul
Re: Use of Sky Go clarification
It *should* work in that you can only set recordings, you will be unable to view tem so can't delete any so I would suggest settings as many as you can before you leave the UK.
You should be able to set a recording but as you will know you will need an internet connection to be able to do this.
Avatar for Paulll+watkins
Thanks I will have internet just wanted to confirm that I could control my UK recordings from Spain.
Problem with setting in uk is that I can only record programmes 14 days in advance.
I'm out of the uk for almost a month !
thanks for the advice though.
