1
This discussion topic has been answered Discussion topic: Someone is using my sky
This message was authored by: Bear17
Some one is using my sky on they laptop
Re: Someone is using my sky
@Bear17
I take it you don't want them to access Sky Go on their laptop if so try this:
First change your password:
https://skyid.sky.com/resetpassword/
Then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off. This might not happen straight away but should do soon enough.
@Bear17
