Discussion topic: SkyGo not launching onWindows 10 laptop
Message posted on 28 Oct 2024 08:20 PM
For about two months I have been unable to launch SkyGo. I get the checking for updates and then the window closes as though it times out. Sky support have advised re-install which I've done a number of times without success. Is there a resolution or do I just forget SkyGo?
Message posted on 28 Oct 2024 08:32 PM
Re: SkyGo not launching onWindows 10 laptop
Did you try this to remove the hidden files and folders it uses:
Uninstall the Sky Go app and then go to 'C:\Users\[your user name]\AppData\Roaming (ensure hidden files/folders are visible) and delete the following folders:
Sky
Sky Go
And if it is present (it might not be) the Cisco and/or Synamedia folder in App\Data\LocalLow.
Empty your recycle bin.
Reboot your PC and then download and install the Sky Go app again via here:
https://www.sky.com/watch/sky-go/windows
Message posted on 28 Oct 2024 09:22 PM
Thanks caesarome. The only difference that made is that my laptop runs incredibly slowly. SkyGo does not launch.
