5
This discussion topic has been answered Discussion topic: SkyGo doesn't work on my iPad
This message was authored by: Jevo+Senior
Just get a blank screen when I try to open the SkyGo app
Re: SkyGo doesn't work on my iPad
Try deleting the app, rebooting your iPad then installing the Sky Go app again.
Avatar for Jevo+Senior
Thanks! Works a treat!
This message was authored by: Trying_to_use_s
I switched off VPN and it worked.
This message was authored by: biggerbazzer69
I tried that doesn't work still showing technical fault
Switch OFF the VPN then reboot the iPad
