Discussion topic: Sky go won’t work keeps saying technical issues please help
This message was authored by: Alisonmay58
Re: Sky go won’t work keeps saying technical issues please help
@Alisonmay58
Try signing out of the app then reboot your device and the sign back into the app.
If that doesn't work then try linking your Sky ID to your account, help on doing this can be found here:
https://www.sky.com/help/articles/sky-id-cant-access-all-my-services
This message was authored by: craigbennett1304
Hi there, I had this problem. Switched my VPN off and then it worked. Good luck.
CB
