Discussion topic: Sky go not loading
This message was authored by: Jayden2807
Sky go not loading
When i go onto sky go it just swirls and never loads. Every other tab works such as settings. Ive tried several times to redownload the app but it doesnt work.
Re: Sky go not loading
What device is the app installed on ?
Avatar for Jayden2807
It Is a macbook pro IOS
Give this a try:
Uninstall the app 
Launch the Finder, go to the Downloads folder and delete ‘SkyGoInstaller.’ 
In Finder, go to the Applications folder and delete Sky Go app 
Remove Sky Go files 
In the Finder select Go to folder ... from the Go menu (or press c). 
A dialog box should appear. Now copy and paste the following text into the box and press the return key: ~/Library/Application Support/ 
Select the Sky Go folder and delete it 
Empty Recycling Bin 
Reboot the Mac
Download and reinstall Sky Go
