Discussion topic: Sky go grid view
This message was authored by: daveiw100
Sky go grid view
Sky+ app had TV Guide (grid view), but Sky+ is no longer available and has been replaced by Sky Go, which does not appear to have Grid View option.
How can I display TV Guide on Sky Go app?
Re: Sky go grid view
The 'TV guide' option at the bottom shows a grid view.
Avatar for daveiw100
Thanks for your reply
the TV Giide option does not display a grid view (TV guide). It only shows what's on now for all the channels
BTW I'm using iPhone
Ok, it does on PC/iPad.
On iPhone it doesn't have grid.  When you click on channel then programmes are shown vertically.  (Presumably because they don't think there's enough screen space for a readable grid)
Grid view is available on Sky+ app on iphone, so Sky Go app is a step backwards😫.   Sky Go  has replaced Sky+ so why is Grid View not available?
This message was authored by: ConfusedGraham
I have searched for an answer but to no avail. I have sky go on iPhone and iPad. On iPad I can get grid view fir to menu. However my iPhone will not and just lists programmes. Surely if it works on my iPad then it should work on iPhone. Otherwise sky have two apps doing things differently.please help.🤔
Apps can work differently for the size of screen on the device, you don't need 2 separate apps 🙂
